Questions on Venting the Valve Covers (PCV)
I want to add a vent to each of the valve covers using -6AN fittings and hoses. Both cover vents will be routed to the intake tube near the TB. Can I use a tee at the intake tube and still get sufficient flow. Is a -6AN hose (1/4” ID) too small or do I need to go bigger? thanks,
