pcv lines
pcv lines
Aquired a ls2 from a corvette, did not pull the engine, I need to know where the two lines off the valve covers go. The front one seems possible to a port behind the throttle body, the back one??? Is there no pcv valve as on the older engines?
Thanks
Thanks
Do a search for this. Its been discussed before. Yes the front on goes to the T-body. The rear is blocked off. the pcv should come out of the block cover plate [the one under the intake]. There should be a fitting sticking out on the pass side behind the T-body.
