Pass Side LS1 Valve Cover won't fit on LS3 Head, WTF!!!
I'm installing a built LS3 into my 2001 Camaro SS and the Pass side valve cover won't fit.
The Comp Cam rocker trunions are hitting the baffles on the inside. The drivers side valve cover goes on fine.
What the hell am I suppose to do now? My LS1 valve covers are chrome plated and I don't want to get new ones but it looks like I will have to.
Do I need to get a Pass Side LS3 valve cover to make this work?
Bill
Bill
you can keep it as-is if you want, the ls6 setup is not a necessity. you can find info on the swap here:
https://ls1tech.com/forums/generatio...-question.html
the new part numbers you'll want are:
12577927 for cover/gasket/bolts
12594779 for molded hose (or you can just use regular hose, this just looks cleaner)
