FAST 92mm Big Mouth Throttle Body Sticking?
Has anyone had any issues with a 92mm FAST Big Mouth throttle body sticking? I have heard of issues with the older 90mm throttle bodies but none of the newer ones that I know of?
I have one that I think is sticking.
Cheers
Benno
Cheers
Benno
Did you check to see if the blade is rubbing against the body and getting stuck? If so you can losen the bolts to the blade and re-adjust it. I usually losen the bolts up and close the throttle. Then I just open/close it a few times to make sure it's not sticking and then I just tighten the bolts.
Hope this helps.
Hope this helps.
Thanks guys, its definately sticking. Car was prettys warm last night and throttle got stuck at 2% at one stage.
I will try the above suggestion and see how it goes.
Cheers
Benno
Cheers
Benno
I've actually been lazy lately and haven't played with it at all.
I have noticed though that after I've been on a long drive the throttle won't go back to 0% and sticks at 2%. This means the car doesn't fall back into its idle routines etc.
I've actually ordered a new Nick Williams throttle and FAST intake so not sure if I'll mess around with it much. I tend to think though the FAST throttle must be getting warm and parts expanding maybe which then causes it to stick?
Cheers
Benno
Cheers
Benno
Cheers
Benno
Cheers
Benno
Thanks for the info, Benno. I have an early FAST 90mm that sticks when the throttle is closed. Trying to figure out how to fix it. All the threads I have come across are about them sticking at WOT.
No probs mate, mine is fine at WOT.
I have heard of people putting an extra spring hanging of them to help it return better? I don't like the idea of this though as it would make you throttle pedal a lot firmer, but maybe something worth a shot?
I found my FAST throttle body already had a lot firmer spring in it than my old throttle body which I didn't like.
Cheers
Cheers
Cheers
Cheers
I installed a black widow tb. It sits fine when it feels like it at idle. But i wen give it throttle wont return to 0%
Hangs open. Idles at 2000. I give it a few revs and falls back in place when it feels like it.
Also hanging the throttle open during driving. keeps at 2-2500rpm.
I can feel it manually that its not returning to 0%.
Alredy moved around,plate.centered it. Lubed the shaft. Feels like its the bearing or shaft inside.
Anybody rebuild tbs?
Any ideas? Replacement springs or parts?
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
i'm having an issue with my edelbrock 90mm sticking at idle. from idle you have to force the pedal untill it's open and it always makes the car jump.
when the car is off the sticking is gone.
could there be so much vacuum at idle keeping the blade closed? other wise it works great. if this were a race only application this would not be a problem, how ever this is a built 6.0 DD. any ideas?
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
