Lsx 6.0 Iron block build (questions)
Been out of the gasoline scene for a while. Been playing around with diesel motors. Going to swap a ls2 6.0 iron block into my 1995 firebird (lt1 5.7).
Looking to go FI, 800rwhp is a goal number. I was thinking Callies I beams, Weisco pistons not sure on crank yet. I will probably go with a H/C package from AI. Not sure on intake, injectors or who makes a nice single turbo set up for the ls2.
LS1Tech Premium Sponsor
Stock crank, Compstar rods, and Wiseco pistons would do the trick and be plenty strong enough for that power!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
See i have a 6.0l aluminum block and i wanted to get some input on whats set up to run im wanting to be at least in the 600rwhp range all motor and 700-750rwhp on spray any suggestions?
