Best MAF sensor to use with LS3 SWAP into 98 SS? In the process of swapping in a GMHP LS3 376ci/480hp Hot Cam Crate into my 98 SS ive got everything i need besides the MAF sensor. Im using a 92mm throttle bady and just wanted a little input on which MAF will be the best choice for my setup. |
A GM unit, either a 85mm Z06 or a Card style MAF. If you interested I have a 85mm Z06 Maf just sitting on my shelve still with the screen in it, works perfect. |
Definantly..... What would you take for it and where are you located? |
Send me a PM with your address, I will sell it for $35 shipped |
I went with a LS7 card style maf. Theyre really cheap and allow for a much freer flowing intake. You just have to re-pin the connector and tune for it but its nothing too difficult. |
10-4 Ill definantly look into that option too... Thanks |
Where did you find a housing for it? |
I like my Texas Speed 100mm MAF |
Originally Posted by DerekH85
(Post 16733119)
Where did you find a housing for it? http://m.summitracing.com/parts/NAL-19166574 |
Originally Posted by C5natie
(Post 16734318)
Cheaper alternative, mount it wherever you want. In my case, I used a C6 Z06 intake. http://m.summitracing.com/parts/NAL-19166574 |
Originally Posted by stereojnky
(Post 16734819)
Or you could use this one. http://m.summitracing.com/parts/spe-9705 |
If u want fast throttle response then I'd go SD! I got it and I love it! Just my .2 |
© 2024 MH Sub I, LLC dba Internet Brands
