01 SS Build Questions
I have a 2001 SS Camaro
Automatic with 3600 edge racing stall
Pacesetter long tubes
3" Magnaflow catback with electric cutouts
Nitto 555r's
Tune
Car dynod at 350 HP
I want to get some LS6 heads (243)..a TSP MS3 cam, with a D1SC Procharger.
What's the best route I should go? Is there a different head/cam combo that would be better?
Thanks fellas!
-01EvilSS
Nitto 555r's
Tune
Car dynod at 350 HP
Thanks fellas!
-01EvilSS
If your going to use an MS3 cam for boost you have to make your exhaust freeeee flowing or you'll blow boost out the exhaust port with the overlap of that cam.
Ms3 is a top end cam so you'll be wishing you had a bigger stall to compensate
243 heads are great heads but ported 317s are better for boost. Don't cheap out on valve springs. Get a good set of .650 with titanium retainers and hardened push rods
