Stock 5.3L help
Old Oct 2, 2015 | 10:28 PM
Colemanj9483's Avatar
Default Stock 5.3L help
Hello LS guys. I have a completely stock 5.3 w/169k miles on it which I'm swapping into a classic Gbody and my question is. If I change the 862 stock heads to 799 stock heads getting the Chambers milled can I still run the stock cam or would it be wiser to upgrade the cam to? And if I upgrade the cam what kind do you guys suggest? Keep in mind this a weekend driver. Also with my set-up I'm going to be installing a Holley mid-rise intake and also a Holley hp efi ecu & harness kit and injectors.
