Gen 4 motor converting it to gen 3. ?? - LS1TECH - Camaro and Firebird Forum Discussion
Thread Tools Search this Thread
Old 10-04-2015, 11:32 PM   #1
"I MAID THEESE"
Mavn's Avatar
Default Gen 4 motor converting it to gen 3. ??
I have a 1993 z28 that had a 1998 harness and an ls1 . I just built a 416 out of an l99 block . The block has a 24 reluctor , I'm running cathedral heads and a 3 hole cam. What timing set and front timing cover do I need? And what other things am I going to have to convert on this block to run this motor with that wiring harness/computer?
Thanks guys! I wasn't really sure where to put this. Maybe there's a better sub forum.!?
-Mavn
Mavn is online now   Reply With Quote
Old 10-04-2015, 11:34 PM   #2
"I MAID THEESE"
Mavn's Avatar
Also I'm assuming im going to have to run an ls3 valley cover?
I also got the ls1 to ls3 cam/knock sensor harness adaptor
Would this be the timing set I'll need?
http://www.lingenfelter.com/mm5/merc...egory_Code=C38
Old 10-05-2015, 09:40 PM   #3
S10xGN's Avatar
The valley cover has to match the block, so you'll need the late style which requires movement of the knock sensors to the outside of the block. That is the wrong timing set, you need a 1x upper gear and the late style front cover with cam sensor in it.
S10xGN is offline   Reply With Quote
Old 02-01-2016, 04:45 PM   #4
soloman369's Avatar
See i knew i was right lol
soloman369 is offline   Reply With Quote
Old 02-25-2016, 12:36 AM   #5
Default Msd6010?
Will the 6010 box work with the front cam sensor? Where to find gen4 covers?
OkieDave is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Z Twenty h8 VS MAVN - Stroker Catfish in Catfish crime Mavn Street Racing & Kill Stories 13 10-27-2016 02:06 PM
converting Gen3 ARP bolts to GEN 4? Mavn Generation IV External Engine 3 04-22-2016 04:10 PM
TX2K Roll Racing - Mavn Mavn Street Racing & Kill Stories 32 04-09-2016 08:35 PM
Built motor, big turbo, Meth e85 srt4 vs my 1993 z28 Mavn Street Racing & Kill Stories 18 02-15-2016 09:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
