PAC-1218 Good with Boost with L92 heads and LS9 Cam?
Hey guys, tossing a ZL1 blower on a LQ4 6.0 with a set of L92 heads along with a stock LS9 cam (going into a 2003 RCSB). I figure 1218's have got to be better than stock LS3 or LS9 springs.
Planning on 12 psi max boost (2.45" upper pulley, 10% overdrive crank pulley) in the 6000-6300 RPM range. Are 1218's enough for L92 valves being they are slightly heavier than hollow LS3 intake valves? I already have the springs from another project, never used. The next step for me would be a BTR .660" double spring kit, but if the 1218's will work, that saves me $230.
Thanks!!
Thanks!!
