Will accessories from a 4.8 mount on 6.0 or 6.2?
Ok guys , I have another question. I'm preparing to find a 6 or 6.2 to swap into my silverado with a 4.8. I know the ECU and wiring from the 4.8 will work after a tune but will I need a complete motor donor or can I swap all my current accessories right onto the new motor? Buying just a long block is much cheaper. Thank you
You shouldn't have an issue swapping over accessories. Also, correct me if I am wrong, 4.8L shouldn't have AFM and neither should the 6.0/6.2? Not 100%.
I am doing a similar swap but mine is an '07 Classic. Good luck!
Restricted User
