gen iv LS3 wiring
Old 01-15-2017, 07:06 PM
opietailor's Avatar
Default gen iv LS3 wiring
What I got is a gen iv LS 3 connect and cruise crate motor. It is being installed in a 1968 conv chevelle. I have American Auto Wire Update kit and Dakota Digital VHX dash I am installing. Anyone match these together? What do you need to use and not use on the GMPP harness?
Thanks
Old 07-25-2017, 08:33 PM
bens55's Avatar
Did you ever get any answers on this? I am doing the same build on a 55 Bel Air.
thanks,
Ben
Old 07-26-2017, 06:50 PM
clinebarger's Avatar
thanks,
Ben
What are your exact questions?
You have a American Autowire classic update harness, Dakota VHX, & a GMPP connect & cruise?
List the wires on the engine harness that you need to terminate & I'll tell you what to hook them to.
Old 09-10-2017, 06:49 PM
Ramjet51's Avatar
Default LS3 wiring
Anyone have the diagram for the connect and cruise
Old 09-16-2017, 12:58 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
Chevrolet performance website...under support...
Andrew
Old 09-17-2017, 07:18 PM
Ramjet51's Avatar
Andrew
Nope...you're more savvy with that POS site if you can find a link, it's only blah,blah, blah installation notes, not a link to wiring that I can find...
Old 09-20-2017, 02:43 PM
https://www.chevrolet.com/content/da...except-lc9.pdf
Old 09-20-2017, 02:56 PM
Received 3,019 Likes on 2,350 Posts
He had to have seen this on GM's site. I tripped over it almost by accident while browsing their engines
Old 10-15-2017, 12:02 PM
PatTheRat's Avatar
Default interface
highly recommend the BIM-01-2 - ODB II/ Can Interface Module from Dakota Digital. plugs into the interface, connect all gauges, can display all parameters (trans temp, etc)
Old 10-15-2017, 09:30 PM
1989GTA's Avatar
With my 1965 Buick Skylark I kept the two harnesses pretty well separate. That being the chasis/body harness and the motor harness. Power and ground being common and some of the gauges went with the motor such as the tachometer, oil pressure and water temperature.
Old 10-19-2017, 09:26 PM
bens55's Avatar
I used the third brake light wire on the AAW harness for the converter lockup control on the GMPP trans harness.
Quick Reply: gen iv LS3 wiring
