Will LS3 continue to run with loss of crank sensor signal?
I read some ECM's can use cam sensor signal to compensate for loss of crank position signal, although not very smoothly, but engine will still produce power , and likely won't start with just cam sensor... Do the GM Performance ECM's have such ability? Is there a way to disable limp mode on GM ECM's and allow this. Would be helpful for off road applications.
