my stuff on my ls2
my stuff on my ls2
hi my friend
for my first post here i share my setup for drag racing application in '94 mustang
I would like to know how many approx HP my setup make and i need time slip from similar car because i'm not sure how many weight my mustang is just stripped
tanks you and your comments will greatly appreciated
i'm start with a '05 6.0L
Rocker Arm full roller 1.8 ratio #summit : comp CCA-1675-KIT
Holley Valve cover tall height #summit : HLY-241-110
camshaft hydrolique roller #summit : COMP-54-448-11
intake gasket set fel-pro #summit : FEL-13123
head gasket fel-pro 4.100 bore #summit : FEL-1161R041
head gasket fel-pro 4.100 bore #summit : FEL-1161L041
chromoly push rod #summit : TFS-21407500
MSD wire set 8.5mm #summit : MSD-32829
hedman headers #summit : HEAD-45660
edelbrock intake super victor #summit : EDL-28097
professional product damper #summit : PFS-90033
ict billet oil cooler port #summit : ICB-551621
cloyes double timing chain #summit : CLO-9-3159A
B&M flexplate SFI 29.1 #summit : BMM-20340
holley dominator 900CFM carburator USED
stroker kit eagle 427ci USED
TH400 trans full racing USED
torque converter custom build
trick flow head 225 CNC port USED
manley complete Valve train USED
4:10 ratio
4:10 ratio
Pantera EFI EAP Question
Hi, I do an EAP for LS-1 Tech members for free.
I see you provided some specs, I need MORE.
Head port flow #'s, cam spec's, exhaust pipe length, etc.
Lance
Lance
