LS2 into C5, 1 or 2 wire Knock sensors
Hey guys,
I'm approaching installation of a LS2 into my 2004 C5Z. I've read that the 2 wire Gen4 sensors will not work on the earlier C5's, but how about the later cars. Racetronix sells adapters/extensions for both style sensors. The smaller newer Knock sensors would make install easier id assume with the headers. Let me know what you guys think.
-George
-George
If you can, test fit the headers with the engine out, then decide where you want to put the sensors. There are a couple pre-drilled locations you can use. The holes are too small, but it makes enlarging easier since you just go the depth already drilled.
