Carbon airboxes with the Harrop Hurricane on an LS7
#61
Thank you for that helpful information. I wasn't aware of the integration, and that I can specify a MAF version from Harrop.
BTW, my raised hood finally arrived from New Zealand so the Hurricane should fit without any interference. I would still solicit your help for a clean tubing transition to the Harrop air/filter intake (post #30 pic-1). Granted, it requires quite a prep work, but you may get the idea.
#63
Moderator
Received 1,835 Likes
Fueling -- SD works, but I would blend in Alph-N. That's a rpm vs tps table. Help refine that fueling quite a lot. The HPTuners custom SD OS has this
#64
Yea, that's how it's currently set up in mine. But you don't feel a difference in running the car with that or on the MAF.
#65
Moderator
Tells me how you have the maf situated, it is not a restriction to the intake. Run a 100-mm card maf to a big cube motor, and it takes up a ton of area, so it acts like an intake restriction. Cool you were able to eliminate that.
#66
Thanks! It was verified with CFD to place the MAF in a location and just poke it in enough into the tube where airflow was clean enough to get a good signal. The two 102mm inlets do help for the reasons you mentioned though, but there was almost no other way to go around that anyways, so it worked out quite well that we're still getting good signal at idle.
#67
#69
Moderator
I would guess the stroke. Typically when I see similar engines tested with similar top ends, I see similar power, edge in torque to the longer stroke, and peak HP while similar is at a higher rpm on the shorter stroke
#70
I see another Maha dyno test!? This one is interesting for me as i can see another comparable dyno sheet, as opposed to the ones in the US where the power figures seem to be so much bigger, you Americans must have some kind of magic air
My graph here is a Kinsler 55mm ITB set up on a 419CI LS3 (4.085x4.00") AFR Cathedral 245 heads.
The lower graph on my one Here is a 454LSX with a Fast 102 on the top.
#71
Moderator
Damned metric units. At first I thought graph was effed, because the lines don't cross at 5252. LOL.
IMO, 55mm seems small for a 419. I know for my 428, Lance was recommending 65mm. How would you expect throttle size to affect the curves? Carrying even better up top, or possibly raising the torque curve down low?
#72
On this Maha Dyno I have seen an LSX454 with mast heads and a cam heading upto around 300 exhaust, and big headers twin 3” , plus 60mm ITB set up, that did 680bhp, mine made more torque upto about 4K then it pulled away, not that different to how mine looks against that stock 454lsx I’ve used as a comparison.
#73
Moderator
Oh yeah, with that if you're anything, it's exhaust limited. Certainly nothing to be disappointed in. I'm sure it's a handful to say the least. Your 0-160 video is impressive. Thanks for the info on the other 454. I think that is pretty much what I was wondering about.
In order to fit a ITB on mine, because F body cowl, the biggest I can go is 58mm, but I'm hearing 65mm is a better match for the motor. So I was curious what your thoughts and experiences were on TB sizing affecting power and performance. I bet that thing does respond quite snappy.
Nice work man
Nice work man
#74
Nice work man
Nice work man
Another thing of note mine is not a X over set up, so my runners are shorter, actually the identical length to FAST mid runner, i researched this to get the power band to peak at 7k, and it actually worked, I was quite pleased to find out that Fast agreed with me!
#75
Moderator
Thanks, that wild 454 was up around 50bhp from an MSD intake, that 0-160 vid was with a Fast 90 set up, i’ll Bet it’s close on 100bhp more and this now really revs!
In lots of brackets, ITB is considered a power adder. Guess you're seeing that yourself!
#76
Nice work man
Nice work man
#77
Damn that math, it works every time it's used! I'm sort of stuck with X-over due to the "DNF" cowl. But still if you're doing so well with 55mm, I should be fine on 58mm. The fast mid runner IMO is a very good runner length. I do find in the postings and such that the larger engines seem to just respond well to shorter runners, sometimes even at lower RPM. My guess is just raw airspeed with larger cubes means the shortest straw flows the best.
This Macca here is around 900bhp N/A, they said they can get more but its got to go around corners too. I regularly attend events where this competes and it is savage!
But you can do things like this if packaging is no obstacle.
#78
That's really interesting. Given that a well designed intake tract and intake port should have a fairly consistent taper to the valve, it seems like 65mm bores are about the minimum size you should use in an ideal world with a 2.20 intake valve. 65mm is 2.55", and I expect the ITB blade to be ~9 inches from the valve face. The intake port runner length alone is ~5.5 inches.
55mm is 2.165", same as an LS3 valve. A 2.2" LS7 valve will not be happy with that in front of it. I think you'd start seeing intake tract depression like you do with a single plenum intake.
#80
The fact I managed to pack the reversion at exactly where i wanted has more effect at this point i think, I did some dyno back to back with some stack lengths a while back and that was very significant, like 25bhp or so if I remember, if your cam is trying to peak where the pulse wave is not then you are p!ssing in the wind.
ETA, I found the sheet! This was swapping the trumpets nothing else, no fuelling changes just a down and dirty swap and blast just to see. This was my old 416CI motor but the basics still apply.
