L76 swap to LS2
For afm delete you need at least
Lifters and trays
Head gaskets
Head bolts
Exhaust manifold gaskets
Valley cover
Tune
The optional parts are
Valve cover gaskets
Coolant xover gaskets
Intake manifold gaskets
For vvt delete you need
Single bolt or 3 bolt cam gear (with bolts)
Ls2 Timing chain tensioner
Ls2 front cover
Water pump gaskets
Crank bolt
Cam thrust plate
If you have both afm and vvt youll need a reg style oil pump
Timing chain is your call as its the ls2 chain anyway. replace if high miles. valve stem seals are the same way.
If you need help with any of that let us know.
The vvt isnt going to gain you as much as you expect though honestly. It is more $$ to delete it, but well worth it in my opinion and experience.
Trying to tune a vvt setup correctly takes an experienced tuner. Yes tsp can give you the info but that is only for locking out the phaser and positioning, not the actual cam tuning itself.
Your choice just giving all the facts. Ive had better luck removing both and going with a std cam vs any vvt setup even with hours more tuning.
