Trickflow 255 ls3 heads
Lift isnt the only part to consider how aggressive a lobe is. The higher rate spring would be better for higher rpms or more aggressive lobes but have a 1.080 coil bind so arent rated for as much lift roughly .650. It will depend on the rocker arm used and weight over valve as to whether or not youd want to jump up to the higher rate.
