Trickflow 255 ls3 heads - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 12-06-2017, 05:58 PM
Default Trickflow 255 ls3 heads
If you buy the bare casting Trickflow 255 ls3 heads do they come with valves?
andy-lswon is offline
Old 12-06-2017, 08:44 PM
NO ! Bare is bare .
1973 STEP A SIDE is offline
Old 12-07-2017, 12:39 AM
Originally Posted by 1973 STEP A SIDE View Post
NO ! Bare is bare .
thanks for the info. Looking into upgrading heads and just trying to get some prices added up
Old 12-07-2017, 10:07 PM
NO ! Bare is bare .
If I ordered "assembled heads" while I have to purchase valves; springs; etc.....?
LOL
Jimbo1367 is offline
Old 12-07-2017, 10:39 PM
LOL
NO! Assembled is assembled. lol
G Atsma is offline
Old 12-08-2017, 01:32 AM
LOL
The 'top' springs on the TF heads are good for .650" lift. As long as your cam lift stays a bit below that, you'll be fine. Personally, I like to keep cam lift at least .030" below the lift rating of the springs if I plan to race the car.....but that's just me.
KW
KW Baraka is offline
Old 12-10-2017, 07:30 AM
thats a good idea.
Old 12-10-2017, 10:38 AM
KW
What is the difference in the 2 spring options with the trickflows
Old 12-10-2017, 10:45 AM
KW
I have a set of btr .660 springs in my stock heads and wondered which ones would be the better option
Old 12-10-2017, 04:08 PM
Are you gonna run a stock cam?
KW
Old 12-10-2017, 04:36 PM
Truck Premium Sponsor
Trick flow heads use a different length valve than normal. So if you are looking for valves plan accordingly.
The trick flow springs will be a better option really. They are PAC. The real difference is spring pressure as both can handle good lift, really depends on installed height though which i dont know. the T001 has the 370lb spring with 1.010 cb and the T002 has the 450lb spring with 1.080 cb.
Remember they will need a 7.750 pr at least. For that length youd really want an 11/32 pr or 3/8 or at least a .120 wall.
tech@WS6store is offline
Old 12-10-2017, 05:53 PM
KW
I plan on using either the cam motion titan king or btr stage 4
Old 12-10-2017, 05:54 PM
of the 2 spring options which would be comparable to the Btr. 660 springs?
Old 12-10-2017, 06:59 PM
The T001 have a better rate than the btr but are closest. Use them.
Old 12-10-2017, 11:56 PM
I was asking because I have a set of the Btrs in my stock heads with my current set up and wondered if they could be used in these heads
Old 12-11-2017, 10:17 AM
The trick flow valves are heavier than stock and you are looking at a heavier roller rocker also, the higher spring rate would be much better plus brand new.
Old 12-11-2017, 10:42 AM
I plan on using either the Btr stage 4 or cam motion titan king to go with the heads. Since you recommend using the T001 springs which is the 370 lb version correct? How much lift are those springs good for?
Old 12-11-2017, 10:53 AM
Coil bind is 1.010 and installed height is 1.780 iirc for those so .700 lift would be fine.
Old 12-11-2017, 11:59 AM
so basicly you're saying the ones with the cheaper springs would be what you recommend. Is there a difference in the lift they can handle? I know the Btr stage 4 is pretty conservative on lift so it should be easy on the springs for as big a cam as it is
Old 12-11-2017, 12:04 PM
Lift isnt the only part to consider how aggressive a lobe is. The higher rate spring would be better for higher rpms or more aggressive lobes but have a 1.080 coil bind so arent rated for as much lift roughly .650. It will depend on the rocker arm used and weight over valve as to whether or not youd want to jump up to the higher rate.
Quick Reply: Trickflow 255 ls3 heads
Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
