lets talk fuel injectors, do they matter. are there any real gains switching them out
ok so fuel injectors, are there any real gains to justify costs moving up to a high lbs/hr injector. can a good tuner set the dwell time in the tune or does a good upgraded injector take that same voltage and just hang open longer. please school me in the world of aftermarket injectors. thank you guys.
If you aren't examining the injector duty cycle with tuning software then you only have your horsepower to go off of. The more horsepower you make, the more fuel you require. You might want to consider upgrading your injectors for a heads/cam/intake/full exhaust upgrade. You'll definitely need larger injectors for nitrous and turbo applications. What are your current mods?
im sure there is, but with the amount of time it would take for me to find the answers i know there is someone itching to express their knowledge and feel like they helped someone today. some call this laziness, i call it just wanting straight answers.
Fuel Injector Tech
Hi PT, as you see from the posts NO ONE has answered your question.
I supply a DENSO injector of 450cc as common to the LS engine.(500HP)
The users state the Idle quality IS better than the OEM injector.
The REASON is fuel droplet size of 2-3 microns vs OEM of 5-6 microns.
The common newest injectors have a smaller fuel droplet size good for HP increase and a fuel mileage increase.
IF you question was as observed, I too have that answer.
An upgrade to a larger, MODERN, fuel injector allows for the fuel delivery to be MORE directed at the OPEN valve. (50%-60% Duty)
This is VERY GOOD the reduce T-fuel, allowing the engine to make more power.
The EMS/PCM must have the object, the Injection Instant that allows for adjustment to be correct.
My ECU-882C does this with advancement of injection as RPM is increased.
Fast sells injectors they do NOT manufacture, WHAT is their manufacturer ?
Lance
Lance
Lance
Lance
I agree with Lance, proper injector pattern and aim is important. many get by without worrying about it, though.
as far as tuning, it depends on the injector. ECM software will calculate the appropriate pulse width based on calculated cyl charge, feul trims, injector data, etc. What the ECM needs is the right injector flow rate table, voltage offset values, min pulse width values, injector timing in relation to exhaust valve closing (which is based more on your valve event timing than anything else), etc etc etc.... these are all in the calibration and a good tuner will know what to fill in based on what injector he is tuning for.
