ARP starter bolts for LS3
I am awaiting delivery of a GM Performance 376/480 crate engine...i ordered some starter bolts from summit but they may have sent the wrong ones...there is one really short bolt and the other is long....anybody have a part number the proper ARP starter bolts?
Google is your friend:
Chevrolet M10 x 4.470˝ UHL, 2 long, hex - Kit #: 430-3512
http://arp-bolts.com/kits/ARPkit-det...?RecordID=5102
Chevrolet M10 x 4.470˝ UHL, 2 long, 12pt - Kit #: 430-3511
http://arp-bolts.com/kits/ARPkit-det...?RecordID=5101
That'll mostly depend on the starter you're using, not so much the block.
IIRC the 5.3 starter used 2 equal length bolts but you know how it is... they say the 2nd thing you lose as you get old is your memory, but I can't remember what the 1st one was supposed to be...
Do yourself a favor and get the new design bolts. You do not want to run the old style unless you want your block breaking off at the starter and then have to spend $400 on the starter bridge to patch that crap up lol
EDIT: So after spending an hour reading through old threads on here, I sprung for a new truck starter utilizing the thicker mounting surface with the longer bolts. Not going to risk breaking off the starter mount on an expensive new sleeved block over a $50 starter.
