Need help sorting out 2007 Escalade harness
Old 04-09-2018, 09:20 PM
Suprathepeg's Avatar
Default Need help sorting out 2007 Escalade harness
Picked up the donor motor for my model A.
Sadly the harness was pulled without any of the connectors being labeled. Does anyone know where I can get a map to label the connectors on this harness?
Old 04-10-2018, 10:20 AM
pantera_efi's Avatar
Default Keyed Connectors = GM Harness
Hi A, the harness uses Keyed connectors BOTH color and connection.
I own a 2007 Escalade, I could answer specific questions.
Yes to your question as we make the Harness for use with MY ECU-882C.
There is the cost to allow the OEM PCM to operate in a Ford Model A. ($600.00-$800.00)
THUS the cost of my ECU-882C is only a small increase AND YOU can change the tune we install easily.
I manufacture a DBW/DBC Cable conversion for the engine, saves the Gas Pedal problems.
The FORD Model A ALSO had a Distributor Less Ignition ! (As in LS engines CNP)
Lance
Old 04-11-2018, 07:45 PM
Hahaha thats funny.
Is there some sort of legend that can tell me what all the connectors are for?
If your in the US there isn't much hope for me sending it to you to work on, I'm in Canada and the exchange is brutal these days...
Old 04-12-2018, 10:18 AM
Default Connector Cheat Sheet = Free
Hi A, I deal often in Canada, my wife's Grandparents built (owned) the Canadian National Rail Road. Her Father was a VP there, then to USA as a SP VP.
The MOST beautiful women ARE Canadian !
You can send me a E-Mail request, as stated we can supply our harness "cheat" sheet with color codes. (GM Standards)
Many times I have customers send items, on a EXPORT VISA, to save duties.
Yes, the exchange rate hurts.
Lance
Old 04-17-2018, 01:47 PM
Pantera I send you an email lemme know if you didn't receive.
Old 04-18-2018, 12:03 PM
Default Pantera EFI Contact
Hi, my E-Mail = panteraefi@lance.occoxmail.com
My phone 949-250-1797
Lance
Old 04-22-2018, 11:20 AM
Default Harness Connections
Hi, I received your e-mail, there was no information.
So I ask, there are different PCMs E-97, E-38, E67 AND there are different Air Door connectors identified by pin count ?
There are different EGO connectors ?
There could be fifteen different combinations.
You could post some pictures ?
Lance
Old 04-23-2018, 07:48 AM
Hey Lance I emailed you some pictures and did try and return your call this weekend. Thanks again!
