C5 alt won’t charge @ idle
Old 05-13-2018, 07:35 AM
jimmyg's Avatar
Default C5 alt won’t charge @ idle
so my whipple / ly6 uses a corvette alt bracket. The biggest alt I could find was a 175 alt. It works fine , but car idles @750 so sometimes it won’t charge @idle. If I tap gas a few times , sometimes it will charge. Other times it stops when it returns back to idle. Drives me nuts . Volts will go down to 10.7 and car will run rich. Right now the pulley is a 2 5/8. Not sure if I can go smaller. Car has an optima yellow top in the trunk. Any ideas?
Old 05-13-2018, 08:45 AM
qweedqwag's Avatar
Mine charges at 800 sounds like you r is on way out.
Old 05-13-2018, 03:49 PM
jimmyg's Avatar
It's only 3-4 mo old . I saw powermaster came out w a 220 amp c5 alt that's supposed to charge good @ idle but it's $375.
Old 06-26-2018, 05:19 PM
00pooterSS's Avatar
That's a bad alternator. 750 rpm is plenty for the alt to charge. The factory idle was lower than that and they charged fine.
