Ported FAST 102 vs stock LS3 intake
Have a 2012 LS3 Corvette that presently just has a Borla Stinger axle back on it. Going to do headers and midpipe (probably Speed Engineering 1 7/8"), and a Vararam CAI. Will be keeping the stock camshaft and 2.56 rear gears but might do a Yank SS 3400 converter. Obviously, I will be getting it tuned also. Trying to decide if a ported FAST 102 (using the factory 90mm TB) will make enough extra rwhp to justify the cost. If I can get at least 20rwhp I would be good with that. If you have any experience with a similar package, let me know how it worked for you. Thanks in advance.
The radius rod tweaked LS3 intake is probably a better value unless you're planning a 7000+ rpm motor
https://ls1tech.com/forums/generation-iv-external-engine/1876724-intake-manifold-flow-test-ls3-vs-rick-crawford-radius-rod-ls3-vs-ported-ls3-fast-lsxr.html
I'm not sure my ported Fast is worth even 10 hp on my 416 under 6,000 rpm
Stock intake is fine with Stock cubes, Stock heads and Stock rpm range. It takes a nasty **** over 6500 rpm. A fast becomes more beneficial when you add better or ported heads or want to rev to 7500.
https://ls1tech.com/forums/generatio...ech-stock.html
And I am the guy with stock cam and mid length runners turning it 7200 lol looking for 10.3@134-135 this fall. When you free one up the fast and 102 TB makes this thing drive like a dream.
