Accessories questions
I have recently acquired an LC9? (2012 aluminum GEN 4) motor to swap into an sn95. A buddy has an LS3 with fbody accessory drive but its in a truck. He has the truck accessory setup but wants to know if he can retain the current crank pulley with the truck accessories, if he can then he will sell me the fbody accessory drive.
Second question, will a truck alternator/ps pump fit the fbody accessory drive or no? Thanks.
Yes, keeping the fbody crank pulley with the fbody accessories would work. Basically, crank pulley should match the accessories. ICT, LSX Innovations and more make brackets and spacers to use different accessories with different sets, but the easiest solution is to keep the crank pulley with the accessories.
