Cant get a f body ATI balancer off
What puller have you guys used to get the balancer off. It has the built in spacer for a f body so the crank bolt is too short or the center shaft is too big to pass through the spacer
I take the shell off the hub and use a 3-jaw puller for my ATI stuff.
I have a MAC balancer puller kit. It comes with several center lead-screws of various lengths. Works great. I also have a MAC installation tool. That one did not have the correct thread adaptor for the LS crank so I had to make one out of a spare LS balancer bolt I had laying around.
I took a old balancer bolt and chucked it up in my lathe and turned the retaining flange down until it will pass through the balancer hole, I also drilled a center hole in the center of the bolt to guide the point on the puller. Works well with my 3 jaw...
