thoughts on new setup. i need your help!
here's what i have thought of so far.
-I got a good deal on a 6.0L short block, being an 06 block, with 07 crank rods and pistons. Katech rod bolts are going to be used.
-for the money i wanting to use the TSP PRC L92/LS3 CNC ported heads, with the hollow stem intake valves, with their spring kit installed.
-this is where i am stuck at. i was searching and found a L92 intake thats tapped for fuel injectors, i then found a "nitro daves" elbow for 4150 carb flange, which is what the carb/efi L92 intake has. so you guys think this setup could make good power with the right cam? any help would be great before i start buying parts. as
thanks
Charlie
