Cam lift with 4-cylinder mode on 09???
How much cam lift can you get away with while still being able to use the 4-cylinder cruise mode? I would think that the lifters can only bleed off so much before bottoming out and opening the valves? If so, is it a problem? Looking at putting a new .590" lift cam (.329" lobe lift) in my 09 G8 and need to know if the 4-cylinder mode needs disabled.
