L92 info please
L92 info please
what elso do i need beside the heads, off set rockers,L76 intake,holly tb or will any 90mm work?
and i have to have my pistons cut? at a machine shop what do i ask?
flycutting depends on the cam and pistons. if the pistons are l92 style then you should be good to go (still depends on cam). any 4 bolt 90mm will work.you need to clearance the baffles in the passenger side valve cover to fit the offset rockers, unless you have really new valve covers. you need an ls3 coolant crossover line and the standard coolant plugs, i had the ls6 coolant crossover and bent it down to make the intake fit. you either need to extend your map sensor wires to fit the front of the intake or t it off the back of the intake.
friend oif mine had a nice 25x cam in his L92 408 and still went 10's na at the track i have no chice but to use the parts i got now if it sucks you can say i told ya so
