Ls2 cam swap?
Old Jul 6, 2009 | 08:16 PM
nick97ta's Avatar
Default Ls2 cam swap?
I have searched and can't find the info I'm looking for, so I hope you guys can help me!
I'm looking at doing a cam swap on a bone stock LS2 in a my DD 06 GTO and have a cam with .566 lift and 232/237 duration on a 114lsa. I got the cam from a fellow member and was told it was a MTI r1 cam. The cam was made buy Lunati, so I called them and was told it only had .566 on both in/exh not the 571/.578 that I have found the r1 cam to have. The lift is not a problem for me for as the cam is a little bigger than I need anyway.
my question is- At what point do you change the push rods? Based off lift or duration?
I know the factory springs are good for .570 lift, but everyone I see is replacing the springs and push rods when they do a cam swap. So what do you guys think?
Old Jul 6, 2009 | 08:35 PM
massconfusion's Avatar
ls2 stuff is significantly better than ls1 stuff. but as long as your doing the cam why not ethier swap new heads in or have the old ones ported and upgrade your rods at least. the reason most people upgrade is peice of mind you know as long as your there why not spend the extra couple bucks to know your car will stay tight and not have a failed lifter or bent rod(more likely of the two) go through the block. its a better safe than sorry attitude is really what it is. I too would rather be safe than stuck on the side of a road
Old Jul 8, 2009 | 01:08 AM
nick97ta's Avatar
I guess I could also put a blower and stroker crank and 15:1 pistons and so on and so on.....
But I don't want to do that. I'm looking for info on how weak or strong the factory stuff is. I'm not looking to be cheap, just looking for info on why.
Old Jul 8, 2009 | 06:16 PM
Andrew R's Avatar
Your going to have everything apart anyway why not just do the springs, retainers and pushrods? It's really not that much money and big piece of mind.
-just do it right.
