Valley cover PCV provisions on ls2 in ls1 car
I put an ls2 in my car and I noticed the valley cover has a spout for the pcv system out front. I just have a rubber stopper over it right now and have my pcv system rigged up how it was on my ls1 with a catchcan. Do i need to do anything special here?
Monitor your oil consumption. The LS2 PCV system is a fixed orifice system and it does not take much before you are sucking loads of oil through it.
There was a train-wreck of a thread regarding PCV system / catch can setup on LS2 motors not too long ago. Do a search for "427 oil consumption".
Come on.....I wouldn't call it a 'train wreck'!
Two threads you should peruse:
https://ls1tech.com/forums/generatio...outing-ok.html
https://ls1tech.com/forums/generatio...ls2-427-a.html
The information that was published in that thread is great. The help you and Tracy provided is fantastic!
