Possible 1st Yella Terra rocker failure
subscribed. Pretty much same thing happened to me about a month ago. Just got my new setup installed in June and had 800 miles on it, still doing a break in for good measures and in 6th gear around 60-65, tick tick tick. By the time I stopped, it had changed to a thump thump thump...exhaust trying to get out but only having 1 way to travel, through the intake. Here is what I found
#7 exh rocker, which I believe messed up the #7 int manton custom pushrod. Trickflow heads.
![](http://i18.photobucket.com/albums/b131/TACE02/brokenrocker001.jpg)
Replaced both intake and exhaust pushrods and rockers. Hope no more break!!!
Why would I downgrade to a single beehive springs when I already have a set of dual springs with a .650 max lift?
What makes you suspect that there way "bouncing" arround in there? Other than where the roller rocker broke, everything else is perfectly fine. When the rocker broke, it caused the pushrod to bounce arround, but only after the rocker broke, not before.
I dont think guide plates would have held together the roller rocker on this one.
Sorry the pics not better, but these have a lot of material around the cup.
![](http://img29.imageshack.us/img29/9827/ra1b.jpg)
![](http://img6.imageshack.us/img6/5426/rar4b.jpg)
Well, I will keep the springs that came with my Trick Flows, as I really have not seen a real reason to spend the extra money to change them out for a single spring rated at the same max lift. If Yella Terra comes back and tells me that I need to, then I will.
Just saw this question. Pushrod is still straight to the eye (not mechanically checked.) The tip that is against the rockers is pitted pretty good, and where the pushrod passes thru the head, there are wear marks from where the pushrod contacted the head when the rocker let go. Other than that it looks fine.
And they pushrods are all marked 7.500 and are TrickFlow brand.
Now I know that I dont know everything, but I at least know this. Just be cause it physically looks bigger and beefier, does not mean it is. It all depends are what metal it is made from and the manufacturing process.
Now I am not saying that that rocker is weaker/stronger or anything. Im just saying just because it looks biger, doesnt mean it is.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Well Saturday 29 Aug. 09, I started hearing a nice very loud ticking followed by a subtle boom and lost alot of power while on my way home. Was almost home when it happened. My second rocker... this time #4 intake...a lil over a month ago my #7 exhaust rocker broke and was replaced.
Well got my car home and started to look into what made the noise... not having a clue what it could have been!!! (Sarcasm). took off the valve cover on the passenger side and to my surprise, well not really...
this is what I saw--
![](http://i18.photobucket.com/albums/b131/TACE02/rocker2001.jpg)
![](http://i18.photobucket.com/albums/b131/TACE02/rocker2002.jpg)
![](http://i18.photobucket.com/albums/b131/TACE02/rocker2003.jpg)
So less than 1500 miles in 2 months (since install) I have broken 2 Yella Terra Ultra Lite rockers... Gonna change them all out now, screw it, I want my car to run for more than a month between down times.
#35
cam specs are 24X/25X over .600 lift 113+3. Not exactly a baby cam...lol.
Yeah, this issue really sux, cause I had only heard good things about yella terra until now. Not really sure just yet what rockers I am gonna go with yet. Would love some Jesels, but holy **** are they expensive, and unfortunately I spent almost every last penny I had for my current setup... :-(
#37
Is Yella Terra coming to the party and getting on top of this? Seems they have a real problem. Maybe the manufacturing has been moved to another country and they are having quality problems.
Quality always great in the past.
#38
I really hate to see this happening waited 2 months worth of back order to get YT rockers because I only heard good things about them. With only 375 miles on new 408 I am really nervous now! Have you talked with YT about this?
#39
i actually had an engineer from australia call me last saturday about them. He wanted to make sure i sent the entire set back and not just the broken one. he has been reviewing both threads (here and on ls1gto.com) and said that my install was perfect and that he feels it was something in the metalurgy when the billit blanks were made. He was a really awesome guy to talk to.
