LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   Should I mill LS7 heads while they're off? (https://ls1tech.com/forums/generation-iv-internal-engine/1199166-should-i-mill-ls7-heads-while-theyre-off.html)
BA. Oct 30, 2009 11:33 PM
I honestly don't know how to do the math, nor what is considered safe/not safe so I'm hoping for a good consensus on this. :) Opinions welcome!
The engine already has forged pistons with these specs:
Rod - 6.077
C.D. - 1.163
Weight - 460
Pin - 9252” (23.5mm) x 2.250”
CC’s - -3.84cc
70cc , 72cc
11.2, 11.0
These pistons use the factory 6.077” Titanium rod, and the stock .9252” (23.5mm) pin diameter
The current head gasket is a Cometic which I think is .040" thickness.
The heads are going to be ported at WCCH and I'm wondering if I should have them milled?
It will see lots of heavy street action, maybe even a missed shift. The cam is still a deciding point but probably between 232 - 242 net intake duration. (.050" lift), and valve lift probably less than .650 for both I/E.
It will be paired up with an LSXR intake and 1 7/8" headers.
Should I leave well enough alone or do I have room to mill? Is it worth it?
Oh yeah, 92-93 pump gas all the way.
Haans249 Oct 31, 2009 08:39 AM
You have plenty of room to mill as I'm sure those pistons have the right valve pockets. What brand pistons are they? Sounds like diamond/Katech. I would mill 15thou to bump your compression to around 11.5:1 (estimate). Also, for you cam choice I would recommend the cam I'm running. It's a 235/250 I/e duration with lift right around .650. I can show you a dyno sheet of the power it made (553/511) through a single 3" cutout. I can also provide you the specs if ur interested, just shoot me a pm.
GMLSX Oct 31, 2009 11:32 AM
you can always take a .002 skin cut to assure flatness, or you could just flat sand them.
© 2026 MH Sub I, LLC dba Internet Brands
