LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   TFS 215's on a 416??? (https://ls1tech.com/forums/generation-iv-internal-engine/1209851-tfs-215s-416-a.html)
RENE'S RAGE Nov 27, 2009 06:27 PM
I have a 382 now, plan on building a 416, with my Lunati crank and rods and a LS3 block. Will my TFS 215 cnc w/61cc heads work on this build or do I need different heads? This will be a track only car.
Also, what would be a good cam ? I have a Vindicator now, 240/244 .605/.596 112+4 LSA
New to the Gen IV scene. Thanks in advance guys.
LS1ROPER Nov 29, 2009 06:18 AM
Look at the Nov 09 issue of GM High-Tech Mag, there is an SS running a 416 with TFS 215
making good power. The same car is running a much bigger cam! You may want to call Ron at Veneance Racing about a cam!
robert miller Nov 29, 2009 07:23 PM
Look at 225 or 235 heads. Alot of guys are running with trick flow 225 is what I am running on a ls2 out only too a 402. 857 RWHP ON A MUSTANG DYNO. Love the ones I have on my car..
RENE'S RAGE Nov 30, 2009 08:27 PM
Thanks guys, I think I need bigger heads and a bigger custom cam. These TFS 215's are some great heads and there brand new. Don't know much about the L92's, but alot of people are running them. Guest I need to do some more research, but any suggestions would be greatly appreciated.
john563 Dec 1, 2009 02:32 PM
what do you put down with the set up you now?
RENE'S RAGE Dec 1, 2009 08:05 PM
465hp, 410tq
RENE'S RAGE Dec 2, 2009 06:18 PM
Anybody else. Still looking for answers/advice. Keep the TFS 215, go with TFS 225 or some CNC L92
Pseudonym Dec 2, 2009 06:27 PM
I would use 235s. You can actually call TEA and they can open them up to 235 from 215. Im not sure how much they charge for that, but is cheaper than buying new heads.
hivoltagedriver Dec 2, 2009 06:28 PM
I would think that if it is a track-only car, the 215's might be a little small for a 416.
Pseudonym Dec 2, 2009 06:36 PM
double post. sorry.
You have a PM.
RENE'S RAGE Dec 25, 2009 01:41 PM
Thanks everyone, but still looking for more opinions.
raymond mckinney Dec 25, 2009 08:16 PM
LS2 Bait made 527 wheel with a 416 and TFS 215's and his streetcar goes Nines with alittle spray, stick shift and full weight. Theirs also so a 402cid with them that makes 540wheel. What are your goals?
RENE'S RAGE Dec 26, 2009 09:01 AM
NA, Turbo 400, 5000 stall, 2900lbs. 10.30's 1/4 mile. Not worried about RWHP, I'm sure over 500 with no problem. My 382 made 465 and ran 10.80's.
Just wandering if I need bigger heads. 225 or 235. Going to get a custom cam and reuse my Fast 92/92 set-up. Around 11.5:1 compression.
hivoltagedriver Dec 26, 2009 10:48 AM
You are going to be limiting your potential with the 215's. Get the 225's or even the 235's and allow yourself some room to grow in the future.Cost difference is negligable up front.
© 2026 MH Sub I, LLC dba Internet Brands
