Pics and flow #'s for TEA ported l92 heads,370 cfm!
Just got my ported l92's in from TEA.This is there Stage 1 port job.I also had TEA replace the stock 2 piece l92 valve with the 1 piece hollow stem ls3 valve,exhaust valves on both engines are the same.It has the platinum dual springs and ti retainers.I also had the heads milled from the stock 69.x to 68cc.
Flow #'s are:
intake exhaust
.100 74.4 58.7
.200 153.6 124.2
.300 228.0 177.1
.400 290.2 214.9
.500 332.6 246.9
.550 346.0 257.8
.600 353.8 265.4
.650 362.1 270.1
.700 370.9 274.7
And thats on a small bore(4.030")
I have read that ported l92's seem to hit a wall after .650 lift,my flow sheets prove that is certainily NOT true.
This will be going in a 2005 Escalade EXT with a ported l92 intake,a 9.3-4:1 compression 408,60# injectors,built 4l65 with circle d 2600 stall,and a 224/236 .600ish lift camshaft.I figure the lower compression will allow me to add forced induction or a good nitrous shot if it isnt fast enough NA.I will be happy if it makes 425 all wheel hp.Anything over that is gravy!
Flow #'s are:
intake exhaust
.100 74.4 58.7
.200 153.6 124.2
.300 228.0 177.1
.400 290.2 214.9
.500 332.6 246.9
.550 346.0 257.8
.600 353.8 265.4
.650 362.1 270.1
.700 370.9 274.7
Almost 50 views and no comments???
I would figure people would be coming out of the woodwork since l92 heads are not supposed to pick up flow well over .650 lift:dunno:
Are these good flow #'s?From what ive seen posted on here,these are AWESOME flow #'s for a set of ported l92's flowed on a small bore.....
Who ported and flowed your heads?Unless it is a MAJOR company with a known good flow bench,Billy bob who does all the pro stock stuff might know how to port heads but anyone can fudge the #'s.
I will pay your shipping to and from TEA if you let them flow your heads.And I will side bet they dont flow near 400 cfm.That is,if they have not been welded on.....
Heads that flow 370cfm on the intake,like these ported TEA's will support over 900 flywheel hp NA.Theres all kinds of things porters ca do to get high flow #'s,esp when charging thousands of $$$ more for a comparable product.
I did a bit of research before I sent my heads to be ported and TEA's flow #'s were the highest I could find from a major supplier.Also,TEA must be constantly refining the cnc program because my heads are flowing more than advertised.
Friends shop in Pensacola?Well theres your reason right there...There are very few people who should be trusted flowing heads....in the south,there are only a handful and none even close to you......get a good shop to flow your heads and see if there is a 30cfm difference....Ill bet not...
So what did your L92's flow when stock on TEA's bench? I would be curious to see how much they gained over the stock flow numbers. I have seen stock flow numbers vary from 313 to 34x on the same casting, just on different benches. FWIW a set of stock LS3's flow 322 on my bench (Superflow)
Seeing as they flow 350 cfm from the factory,I dont think so....-30cfm would mean they dont flow as good as stockers...
im with the poster above, what did the heads flow stock?
if you are so sure your heads flow what they do, but them on another bench.
They flowed 332cfm stock according to TEA on a small 4.030 bore....I have seen MANY post they flow in the 34x-35x cfm range stock,all on larger bores though....easy way to get better flow #'s.
And i know that many,like Patriot,still do not even offer a cnc program becuase they can only pick up a few cfm.Max ported l92's arent going to flow more than 30-50 cfm over stock.
https://ls1tech.com/forums/multimedi...-pass-vid.html
