Introducing the Ultra Track Attack LS7 - 717hp for the hardcore track enthusiast
This is a new engine package we put together for the hardcore track enthusiast. The beauty of it is that it runs on $2.30/gallon, 105 octane pump gas E85. Over 700hp from 5900rpm and up, over 600 ft-lbs everywhere. Specs are below
Bore: 4.205
Stroke: 4.250
Displacement: 472ci
High hp version: 717hp @ 6500rpm, 632 ft-lbs @ 5500rpm
High tq version: 680hp @ 6100rpm, 650 ft-lbs @ 4600rpm
Compression ratio: 13:1
Fuel: E85
Redline: 7000rpm
Weight: 380lbs as pictured
Block: Dart/Katech billet, linerless with nikasil coated bores, billet steel main caps
Crank: Callies forged steel
Rods: Callies forged steel
Pistons: Katech forged aluminum
Heads: LS7
Valves: LS7
Intake: FAST 102mm w/NW 102mm TB
Camshaft: 2 choices available
Lifters: GM racing, hydraulic roller
Oiling system: ARE 3 Stage external scavenge pump, Katech internal pressure pump
Dyno graphs of the 2 camshaft choices
Bore: 4.205
Stroke: 4.250
Displacement: 472ci
Fuel: E85
Redline: 7000rpm
Heads: LS7
Valves: LS7
Interesting spec with the nicasil bores.
What durability testing has been done on this?
There have been problems with nicasil bores on Jaguars and BMW engines before and Jag went back to steel liners.
Im guessing this is a track engine built for performance and not a street engine built for durability? Or am I guessing wrong?
Right, it's built for track use, not street.
