LSA Pistons vs LS9 Piston facts: + Pics
Old 08-04-2012, 05:00 AM
  #41
rsz288's Avatar
I know this thread is a year plus back, google brung me here this time, but am pretty sure the pistons are swapped. LS9 on the right, LSA on the left. The LS9 piston being a forging - hence straight sides and smooth finish. The LSA as mentioned is a casting - with a skirt shape that can only come out of a casting and looks like a regular LS piston apart from the dished crown. FWIW
Originally Posted by Beau@SDPC
LS9 Piston on the left LSA on the right. In case these photos get a little hard to figure out which is which (ill try to call them out) the LSA has the slightly goldish hue to it (making it a ringer for the Hyper E)
Side View - skirts and coating
Old 08-05-2012, 01:50 PM
  #42
Jablowme's Avatar
so they use a cast hyper e on the ls9 what crap !
Old 08-05-2012, 02:23 PM
  #43
briancb1's Avatar
Wow way to actually read bro.
Old 08-05-2012, 03:35 PM
  #44
Oh4GTO's Avatar
Anyone know the CC of the LSA pistons?
Old 08-05-2012, 06:56 PM
  #45
rsz288's Avatar
The piston on the right is the LS9. It is a 4032 forging (higher silicon content than the stronger 2618 forgings but will do much higher mileage and is quieter).
The piston on the left - LSA - is a regular GM LS casting. Apart from the dish it looks pretty well like any other production LS piston. Probably has the inside of the crown moved down to allow for the dish machining. Normally the flat top crowns are 8mm thick. L92 with valve reliefs are 10mm thick. Give or take .
Look closely at the LSA piston on the left. The skirt on the left and right flares out past the pin. The LS9 piston on the right has straight sides - as it it punched out vs cast in a mold. A punch/forging die only goes in straight lines up and down. Though maybe i didnt explain that to well .
Old 08-06-2012, 12:43 AM
  #46
Jablowme's Avatar
thats why i said that jerkoff, the original post is not correct
way to read
allways some smart mouth little punk on the internet
Old 08-06-2012, 05:33 AM
  #47
rsz288's Avatar
Lmao .
Old 08-08-2012, 04:32 AM
  #48
Fb0dy0nly's Avatar
Go back and read what Beau posted again...
LS9 LEFT
LSA RIGHT
Thanks for posting stuff like this Beau, always love to see the actual differences between these things as people like myself will never be able to see the insides of all these different ls motors at once.
Old 08-14-2012, 04:59 PM
  #49
omc8's Avatar
I saw the cost of the LSA pistons , but how much are the LSA rods?
Old 09-15-2012, 10:23 PM
  #50
michaelshobby's Avatar
Default lsa pistons vs ls9 pistons
So say you just bought a gmpp lsa crate engine..what would you do before planting this into your project to squeeze the most out of it? Would you put in ls9 rods and pistons? a mti racing supercharger upgrade? a better cam..or all of the above? At $11,000 for an lsa engine. and $22,000 for a ls9 engine.I think mods can pass the h.p. mark offered for ls9 prices?
Old 09-15-2012, 11:05 PM
  #51
rsz288's Avatar
Cost of LS9 rods pistons and crank would probably go a long way to bridging that 11k gap.
Plenty of ppl getting good power from stock LSA's in CTS-V's.
Old 09-15-2012, 11:09 PM
  #52
rsz288's Avatar
Piston on right is LS9 forging. Piston on left is LSA cast piston. Whatever ya read, seeing is believing .
LS9 LEFT
LSA RIGHT
Old 04-18-2015, 07:03 AM
  #53
Kurtis2short's Avatar
Odd question I bought some new lsa rods isn't there usually a oiling hole drilled through the top of the rod of the oiling of the pin?
Old 05-28-2015, 01:41 PM
  #54
gectek's Avatar
No oil hole.
Also i can confirm that the ls9 is on the left and lsa is on the right.
How do i know? Because I took them.
Beau@sdpc didnt make any of this post. Check the quotes. They changed s/n after i left and Beau took over the position then later left.
fwiw gmpp crate vs gmpp crate the lsa is the best buy.
Any other arguments?
Old 04-12-2016, 05:30 AM
  #55
TT-TECH Veteran
Inspector12's Avatar
I know its an old post, but I was doing some searching and figured I'd mention it for someone else doing the same. Some one mentioned there was no oiling hole on the top of the rod unlike most other GM rods. The LS9 and LSA motors both have piston squirters which may account for the reason GM didn't feel the need for it to get good oiling. But if used in any other application an oil hole might need to be drilled. Not 100% sure, but definitely could be a difference.
Old 04-13-2016, 01:28 AM
  #56
gnx7's Avatar
$750/LS9 Rod! Good God man!
Unobtainium........ mining the Spice? Fastest ZR1 so far on a stock bottom end is 8.30's!
Ported heads/snout/blower/pulley and a nice 250hp direct shot! I'd say the rotating assembly is stout.
Thank you SDPC for sharing this info! Please continue sharing data you find with the new LT1!
Old 08-30-2019, 12:28 AM
  #57
t-1
t-1's Avatar
Does this clear up which piston is which. The lsa can’t go on the titanium rod.
Old 08-31-2019, 09:39 AM
  #58
64post's Avatar
LS9 blocks sure have come down in price, or at least they had for awhile. They are a really nice foundation for any build with billet doweled caps, 12mm head bolt threads, piston oil squirters and supposedly cast differently than the LS3 block.
Old 08-31-2019, 10:23 AM
  #59
bortous's Avatar
The ls9 block is fantastic.
GM rated it 900hp safe which is most likely a conservative figure.
For my next engine it will either be an ls9 or dart aluminium block
Old 09-04-2019, 09:41 AM
  #60
64post's Avatar
Yes, a good choice for an LS9 boosted app or a max effort LS3 build, they’re an L99 block on steroids.
For large bore stuff a Gen 4 resleeve or a Performance Concepts block for bigger budget.
Quick Reply: LSA Pistons vs LS9 Piston facts: + Pics
