Crank shaft timming gear (how do you get it off)
I tryed heat and its not moving its stuck fast is there a trick to getting it off if I use a puller it looks like its just going to break the teeth off the gear ???? Any body got any Ideas. This is my first LS engine I am a old school bb and sb chevy guy so you guys will be seeing a lot of questions from me as I go through this build
LS1 bottom end T Rex Cam 6.0 ported and polished heads ls6 intake thats what I have in mind so far plust the usal bolt ons
some ne had this to say on a nother site.............. The trigger wheel in the stock engine can be
left off in dist engines with or without efi. The one thing that may cause a small issue is the factory trigger wheel is used as a helper in balancing the crankshaft. If you remove it mallory metal will be required in the rear counterweight unless your bobweight is getting much lighter..
