FIRST PICS PRC LS-3 Aftermarket Casting Cylinder Heads Sneak Peak INSIDE!!
After nearly a year of development we're finally to the point where I can show you guys our newest LS based PRC castings! This all new casting is the PRC LS3 cylinder head & will be available in MANY different configurations ranging from LS1 friendly LS3 heads all the way up to large cube LS3 stroker applications! We don't have flow data or anything like this at this time, this is simply a post to let you guys checkout the progress & know we're working hard to make these cylinder heads a reality. The new changes to our castings will allow many new features on both the LS3 head & the cathedral LS heads! Keep your eyes open & we'll keep you guys updated on progress!
Enjoy!
Enjoy!
OWN3D BY MY PROF!
I like that you guys are putting out new products. I look forward to hearing more about them. Do you care to share what all you have planned for them? Runner, chamber, valve sizes? Minimum bore per setup? Are these a modification / retool of the current cathedral port options or a completely different casting?
Keep up the great updates and work, we appreciate all that you do.
LS1Tech Premium Sponsor
it's for ls3/l92 intakes.
We already have cathedral heads available to ship & in stock.
This is a new project for LS3 head applications that want a complete cnc runner instead of working from the GM casting.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
The CNC LS3 heads from Scoggin-Dickey ($750 each assembled) have these flow numbers. How do yours compare?
CYLINDER HEAD FLOW SPECS: (CFM)
.200 .300 .400 .500 .600 .650
INT 153 225 280 324 350 355
EXH 118 180 201 217 230 236
Dave
Dave
It's a little early to be comparing flow numbers just yet. However, everyone has LS3 heads out and available now. The cool feature behind these is they will move a lot of air like the "square" port heads, yet be able to bolt on small bore! (Something that can NOT be done with a LS3/L92 GM casting head.) Not to mention all the advantages that an aftermarket casting offers for guys wanting LS3 heads including thicker deck surfaces for big power adders!
Jon
Jon
So can these be used with LS6 intakes or do you still have to use a LS3 style intake ?
Jon
Jon
They're still square ports and will require the LS3/L76 intake.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The stock Ls3 valves are a little on the heavier side and would seem to limit the upper RPM range.
