ls3 heads swap
ls3 heads swap
are the ls3 heads the same as l92 heads?
when using ls3 heads on my 6.0 what else do i need to use/ change. i know something about the rocker arm offset is different but what else
LS1TECH & Trucks Sponsor
You will need at least 8 new intake rocker arms because they are the offset side. you can reuse your stock exhaust rocker arms if you want. You will need 2 new L92 style rocker arm pedestals. You will need a rectangular port intake manifold, and new fuel rails that will work with the new intake manifold. Also a throttle body to fit on the manifold if you don't have one. Give us a call and we can give you a break down on everything needed.
