biggest cam stock LQ9
I would like to put an off the shelf cam in a stock LQ9.I already have patriot gold springs,7.4 hardened pushrods,LS2 timing set.The motor is carbed,vr jr intake so I guess I'm looking for 110 LSA and what ICL,106to 108? How about the largest comp Thumpr
MASS seller approved
you have 10 to 1 comp ratio so i would say a 228 would work well for a daily driver with a at least a 3200 stall. you could change heads to like 243s and bump comp ratio closer to 11 to 1 and go with a low 230 cam to work best with the vic jr imo. good luck, rob.
