Help me finds pistons
My build is an iron 6.0 with l92/ls3 top end I want a flat top piston with valve reliefs anyone have any recommendations it is a mild build so no need for forged pistons
L-92
I have a 6 liter block and was going to bore it to the 6.2 liter size and use ls-3 or l-92 pistons.Ask your machine shop to sonic check you bores to see if there is enough material.I went with a different combo but still have the pistons for sale.
LS1Tech Premium Sponsor
If you're wanting to go 4.030" bore I'd recommend Wiseco's -3.2cc flat-top piston. They are a very nice piston, with steel top/napier second ring set included at no extra cost, for under $700! Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
