Compression(PSI) for low comp ls2?
Old Jun 17, 2011 | 09:13 PM
oakfan52's Avatar
Default Compression(PSI) for low comp ls2?
I bought a shortblock built for boot with dish pistons. Seller told me it would be a 9.5:1 CR with the stock 243 heads. What PSI would you expect that to produce. The shop said it was 130PSi that seams low considering the factory LS2 is 10.8:1 and its 180-185PSI. Thoughts?
Old Jun 18, 2011 | 12:47 AM
Whistler's Avatar
Sawzall and Welder Mod
Do you know what cam is in the engine and where it was degreed at?
Old Jun 18, 2011 | 11:50 AM
oakfan52's Avatar
It is an LS9 cam and should be at 0.
