427 bore/stroke question
Which combination is better for a NA build of around 550 rwhp?
A 427 with a 4.125" bore and 4 inch stroke?
Or a 427 with a 4.185' bore and a 3.875 stroke?
Hows the Dart sbc short block holding up for a 550 rwhp NA 427 build? Reason I am asking is I am shopping and seeing these offered at what seem very reasonable prices.
The normal ls3 block has issues boring them over 4.100 unless you get them sleeved. You can do a 4.065x4.125 stroke that works but the machine work needs to be good for that long of stroke and pistons made for that combo.
It really depends how it's put together, how it's cammed and what intake configuration you're going to run as to which is better.
Just my $.02
Do the 4.125 bore/4.000 stroke. Pistons are more readily available. If its a street car with hyd roller cam then your probably not going to turn over 6800-7000rpm anyways so the 3.875 stroke will be almost pointless.
Build the 4.125/4.000 combo and focus on getting some great heads. Engine is an air pump, gotta have good heads to make the power.
Original 427 had 4.251 bore and 3.76 inch stroke - back when over square was cool.
These days I'd go with the 4 inch stroke - parts are easier to come by and there is always room for an overbore later. For a street car, you might consider the larger bore and 4 inch stroke. Can't call it a 427 but 44x cubes would be a great engine with the right heads.
