jesel belt drive/or gm front cover-distributor
can the jesel belt drive be used for minimal street use? or does it go through belts/better for track only.
debating whether to do the jesel belt drive and distributor or the gm front cover with sbf billet distributor....
anyone have pics of their set up?
GM cover with the sbFord distributor all the way. I'm using the ready-to-run distributor, basically two wires from the distributor to the coil plus one ground and the engine is running. No wiring harness, no muss, no fuss. Carb'd too, very simple. Wouldn't do it any other way. Sorry no pics handy.
Careful..
I know of a guy that cut the front of the block to accept the belt drive kit, just to find out, that the only oiling system he could now use, is dry sump, and he was not advised by the kit manufacturer.
