LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   ENGINE GURU'S--Engine Leakdown Expectations. (https://ls1tech.com/forums/generation-iv-internal-engine/1524734-engine-gurus-engine-leakdown-expectations.html)
ls427ray Mar 10, 2012 03:38 PM
on a new, just broken-in engine with boost, what are normal acceptable leakdown numbers?
machinistone Mar 10, 2012 09:35 PM
On a fresh motor with the rings seated properly 3-4%, couple more if the ring gaps are setup large for boost, with gapless rings you can see less than that.
racecar Mar 12, 2012 02:01 PM
It's important that they are all consistant. If most are 3-4 and one is 8%, you have bad rings on one.
© 2026 MH Sub I, LLC dba Internet Brands
