oil pan question on 6.0 stroked to 408
Old 05-14-2012, 05:42 PM
mike bondi's Avatar
Default oil pan question on 6.0 stroked to 408
i need to get the truck pan off my motor and go to something with more ground clearance.
the motor is a 6.0 stroked to 408. not completely sure which exact block it is i was told ly6 out of a 2005 truck. i researched and i may be wrong but it looked like the ly6 didnt come out till 2007. havnt got a chance to look for a casting number yet. it is installed in a 91 camaro
my question is will a stock f body ls1 pan and windage tray work with the 408 stroker set up. i was worried about clearance for the crank. also will this be enough compacity of oil to lube the motor. it looks like a 5.5 quart pan and i believe the truck pan is 6 quarts.
i appriciate any and all advice. i have to get this done this week it is way to low and hits everything in the road.
thanks
mike
Old 05-14-2012, 10:11 PM
Gray86hatch's Avatar
I would look into a aftermarket pan with a better pickup location and baffles.
Tim
Old 10-28-2014, 10:52 AM
69Skylark's Avatar
thanks
mike
Mike, what did you end up using I am having the same issue. LQ4 408 stroke.. I need a pan for my 69 skylark
Quick Reply: oil pan question on 6.0 stroked to 408
