Every engine builder should have one of these
If you already have the rear cover off couldnt you put the seal in the cover and use the plastic ring to line everything up? what would be the benefit of this over that? Real question, not trying to doubt what looks like a good product. Also i thought you were suppose to put the seal on without lube because they come prelubed
As you slide the cover on that plastic piece falls off and does not hold the cover in alignment with the crank. That plastic piece is just to hold the seal lips open so they will slide over the crank without folding in. The seal has lube on the lips form the factory. We didn't say to lube the seal, just put some on the tool to help it slide on and off.
Thanks
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Unless the seal is defective and not same size all the way around it will be centered since it is centered in the cover.
Thanks
Christian
__________________
I do like these tools though, might still grab them.
Thank you for your business Brian!
__________________
About Tomis ......
Occupation: Engineer
Ride: Ford Mustang FC
Engine type and displacement: 6.0 LQ4
Tranny type: Automatic
Tires
Hope your not a Ford Fan but seeing as you Have a Ford Bodied FC w a LQ4 in it...You Realized Ford Failed at Engineering a Motor that makes Power and Threw it out for a Chevy......now your bashing Chevy?!?!?! I think your confused PAL!!!! Lmfao!!!
Hey guys, thought I'd do a quick follow-up "review" if you will on the front/rear alignment tools: Motor has a month of driving on it and zero leaks. When putting the rear seal on, it was butter with the GM plastic insert separating nicely as the seal went in nice and square. Wished the oil pump tool was around when I bought these seal tools, but ended up using six feeler gauges from Schumann's pump alignment kit - I would think the Saccity tool would make pump install far easier and much faster than the feeler gauge method. Anyways, these tools are reasonably inexpensive and are worth it to idiot proof seal/cover installs.
#32
Thanks ducatisl for the good word and your business!
__________________
#34
Thanks Alvisracn for your business!
__________________
#35
Gm Motors lack Engineering?!?!?!?!?!?!? (copied Straight from your Profile on here buddy!!!
About Tomis ......
Tires
About Tomis ......
Tires
#37
Thanks you bboyxclub for your business!
__________________
#40
Hi bmr408,
We have them in stock when your ready!:Cheers:
Christian
Christian
__________________
