how to rise compression on lq4 and l92 build
I'm in the process of building a lq4 and l92(with double valve springs) engine for my 86 Monte Carlo S.S. I've been doing a lot of researching for different tips on my build. I read that my compression will be low with this set-up which will cause low torque and poor bottom end performance, but great top end performance. Well I plan on mostly weekend street racing, drag strip and hot ******* with this car. So bottom end and torque is what I Need allot of!!! Most races are over before top speed is reached. So my question is HOW do I rise compression Economically(cheap). I plan on running a medium to large cam and ls3 or fast intake.
Milling the heads .030 will raise it to about 9.9:1 with a couple of other factors it might be a lil more or a lil less. Texas speed sells a few cams for ls3 headed motors. Check out EPS or contact PatG on here, they can spec you a cam for your setup.Hell, the man who posted above me can spec you a cam and get you setup with springs and pushrods too.
If all you do is mill the heads it's .006 per cc so .030 would reduce the chamber to 65 cc. A stock lq4 has 9.4:1 compression with the 70 cc 317 head which happens to be the same cc as an l92 head. Each cc is equal to a tenth of compression. Hence 5 cc is going to raise it to 9.9:1. Putting a thinner gasket will raise it more.
http://texas-speed.com/c-233-camshaf...al-tranny.aspx
A good number of years back, a tech member used the TSP 233/239 cam in an LQ9 with L92 heads and ran 10.80's in a cutlass. His screen name on here was burgers. That cam is meant for cathedral heads but it worked very well with the L92 heads and a carb.
