LS2 build - weird ati damper fit issue
Building up an LS2 402 and having issues with an ATI damper and the front timing cover. Here's what it looks like installed.
Everything was fine until I went to install my crank bolt. Apparently I didn't have the ATI hub all the way back when I installed it so the crank bolt pushed it back. Then, the engine froze and I couldn't turn it anymore. After troubleshooting it, I figured out it is the AC pulley from the ATI kit pressed up against the front timing cover and was jammed.
I took everything off and here are some pics of the various parts of the ATI kit. Do I have the wrong hub or something or is my timing cover wrong?
Thanks for any help you all can provide.
AC pulley from ATI kit:
How the pulley presses against the timing cover:
Pic of the timing cover:
Thanks,
Mowpow
Thanks,
Mowpow
what realcanuck said.
Weird
Yea mine looks like the kit you show in the picture. I thought maybe I did have the AC pulley on there backwards but when it goes the other way (no gap between the pulleys), the screws don't reach the AC pulley from the front so the AC pulley doesn't end up getting secured. The instructions don't indicate which way the AC pulley should go.
